AVS › AVS Forum › Home Entertainment & Theater Builder › Outdoor Theaters › Wanting to get music pool side.
post #1 of 2
Hey all I'm looking for a simple permenant solution to get some music out by the pool. I would like to use 2 or 4 speakers at ground level. I figured I would list the components I have on hand and see what we can make use of. I have a wireless network, an old netbook, smartphones and an ipad. My pool is in range of my wireless network and I have access to 120v outlet near the pool. I will mainly want to listen to pandora or itunes out there. I've researched it a bit and seems like an outdoor cabinet with a receiver/amp might be the easiest option but I though I would ask for any other opinions you all have. Budget for this is 2 -300 bucks.
TIA!
Edited by Shane1 - 4/22/13 at 12:50am
post #2 of 2
Just get a Sonos bridge and Sonos Amp and you'll be all set.
www.Sonos.com
  Back to Forum: Outdoor Theaters
