AVS › AVS Forum › Video Components › Home Theater Computers › Media centre pop up
Media centre pop up
post #1 of 5
For some reason when I use the volume buttons on my remote if media centre is minimised it pops up full screen, this can be very annoying if watching a video online. Does anyone have any ideas on how to change my volume without media centre coming full screen?
post #2 of 5
I'm guessing that your remote is coded for media center volume rather than your AVR or display. Are you using a programmable universal remote?
post #3 of 5
I'm using the remote which came with my origenae m10 I believe its called an imon pad
post #4 of 5
There's an imon setting in the set up wizard about exclusive control of a program. I can't remember 100% what you need to check/uncheck but I used that setting to solve a similar problem with arcsoft minimizing and re opening wmc
post #5 of 5
Okay ill give it a look when I get home thanks for the advice
