AVS › AVS Forum › Display Devices › Plasma Flat Panel Displays › F8500.. OR .. ZT60 ?????
F8500.. OR .. ZT60 ????? - Page 104
post #3091 of 3096
I heard if you watch a Kuro in a closet painted black, the black levels appear to be. 000000001 deeper. tongue.gif
post #3092 of 3096
I heard that astrophysicists have extrapolated that if you were inside a black hole at the very center of it--that if you had a Kuro there that everything besides the Kuro would be a lighter shade of black.
I believe that AVS many centuries from now will fund an expedition to see if this is really true.
post #3093 of 3096
I heard if an LCD passes through a black hole humans could see it from earth
post #3094 of 3096
post #3095 of 3096
Originally Posted by venus933 View Post
Not taking any sides in the arguement but the because in your agreement is not sound. The percentage difference between .00001 and .0001 is huge but I would think the difference between these measurements would be difficult to discern.
Your argument is not sound because no one is talking about a .00001 measured display.
D-Nice just posted his Kuros which measure below 0.0003fL are notably darker than any Panasonics which measure at .0011 in a dark room. Others have noted the same.
These are notable differences because they are in fact larger percentage differences than some realize.
If they were very tiny differences, they would not be discernible.
Why doesn't that sound logical to you?
post #3096 of 3096
When you put it that way it does sound logical.
