AVS › AVS Forum › Audio › DIY Speakers and Subs › My table tuba build
My table tuba build
post #1 of 9
post #2 of 9
Wow. Looks great. I love the top with the center detail.
-Max
post #3 of 9
Fantastic job. I love the granite. How does it sound?
post #4 of 9
Nice work! How does it perform for you?
post #5 of 9
Nice. I built one with two MCM 8s. Mine has similar framing on the bottom, your marble top is very nice. I used self sticking floor tiles with a wooden frame on top.
post #6 of 9
Its sounds pretty good I can already tell I want to upgrade though. The top is actually a concrete top I did, had some left over stuff from when I did my kitchen.
post #7 of 9
You mean you just finished building a nice sub and want to replace it already? Unheard of!! smile.gif
post #8 of 9
I have an idea. Bill think this over if your reading along. Ok here it is:
POOL. TABLE. TUBA.
There you go!!!
post #9 of 9
POOL. TABLE. TUBA.
There you go!!!
