AVS › AVS Forum › 3D Central › 3D Displays › Viewsonic Projector 3D Ready 120Hz VGA only
post #1 of 5
I recently bough a viewsonic projector pjd5123 which says its a dlp 3d ready with 120Hz and has a build in emitter.
i have a retina macbook with a nvidia geforce 650m , two display ports and an hdmi port
the projector has two vga , composite and some other ports but no hdmi.
how can be able to use the 3d feature ?
i have researched alot and couldnt find any answer
what adapter,cable or anything can i use ?
thanks alot
the projector link : (http://www.amazon.com/ViewSonic-PJD5123-Projector-120Hz-Lumens/dp/B004UG3BQK/ref=sr_1_1?s=electronics&ie=UTF8&qid=1366729490&sr=1-1&keywords=viewsonic+pjd5123)
post #2 of 5
Maybe a mini display port to vga adapter? The link you posted has several reviews that mention using some mac adapters.
post #3 of 5
yea but im trying to use the 3d feature, doesn't it have to be converted to digital instead of analog ?
thanks
post #4 of 5
This is beyond my expertise, but seeing as they claim it's 3d ready with its analog connections, it must be doable.
Here's a thread with a person using 3d with this projector (post 5) although he may be using a pc. http://www.avsforum.com/t/1396445/viewsonic-pjd-5123-how-to-display-3d-content
post #5 of 5
Digital still hasn't "caught up to" VGA yet. 3D has nothing to do with digital. I've been gaming in 3D for years with a PC using VGA on an Acer projector. Now 3D from BlueRay is a different story. Has to have HDCP but the Acer has HDMI. And yes, a DP to VGA adapter will work (I have them, came with the AMD Vcard) but not for BD
  Back to Forum: 3D Displays
