AVS › AVS Forum › Audio › DIY Speakers and Subs › Crossover question
Crossover question
post #1 of 11
Hey guys,
I had a crossover designed by Madisound, and it is a 2-way design. I was wondering if I could build off of this design and make it a 2.5 way design. Just didn't know what would be involved in doing/calculating this, or if it was even possible. If this has been covered already please show me a link, I already have done a few searches with nothing conclusive. Thanks
post #2 of 11
i don't know.
if the original design did not intend for a .5 woofer, then your bass may end up too much.
if the .5 is crossed in too low, the large inductor might suck some of the life out of the bass.
otherwise, i don't see why you couldn't wire an inductor in line with a second driver, then wire that in parallel to the rest of the network.
i'm as interested as you are too find out. somebody around here knows the answer.
post #3 of 11
I built the Eton S7 kit. I then paid them $30 to design a mtm version of it.
Why not just have them redesign the crossover?
Here is an extremely unqualified question: If you add a second woofer, don't you need to compensate by lessening the padding on the tweeter?
Edited by Rebel975 - 4/26/13 at 8:18pm
post #4 of 11
I am tossing the original crossover design and I am going to try some free design software to create my own. It may be a trial and error thing, but diy is all about learning. Thanks for your responses.
post #5 of 11
Good idea, I don't think it would work. The low pass transfer function would change altogether.
post #6 of 11
It could be possible. If it was an MTM design and you added two more woofers in order to reinforce the bottom few octaves, it may provide a little more thump if that's what you're looking for. However, they would essentially function the same as an added midbass or sub, so you may as well go that route instead.
post #7 of 11
Possible, yes, with a new crossover. The question is why. I don't see anything to be gained.
post #8 of 11
So if you are building some existing design that uses...say...a 1" tweeter with a pair of 6&1/2" mids per speaker, and the crossover is already completed for this configuration. Can you then add, say...2 more 6 & 1/2" mids that are identical to the existing 6 & 1/2" mids that are aleady in there and connect them in parrell (maybe series, can't remember) using the same crossover? Will this also not bring the low and mid-range up since it would be doubling the drivers cone surface area?
post #9 of 11
No. The impedance load of the mids must be maintained, and you cannot achieve the same load with two and four drivers.
post #10 of 11
If you do that the midrange section of the crossover will see too low of a load impedance, and its crossover frequency will move up about an octave.
If you impedance scale that portion of the crossover then the crossover frequency will be OK, but your tweeter will become weak. If there is attenuation in the tweeter side of the crossover, then reducing it could restore a well-balanced system.
As you add drivers you also end up changing driver acoustical blending, and that is yet another can of worms.
If you hook up the two new drivers through a replica of the midrange side of the existing crossover then that would also preserve the crossover frequency, but you still need to address the tweeter balance issue.
Doubling the number of bass drivers this way will halve the impedance of the loudspeaker system in the midrange, and that may have adverse effcts on the amplifier you use to drive this system.
Probably.
In this day and age it is usually easier and more productive to change the system's tonal balance using the kinds of built-in equalizers we find in modern AVRs.
post #11 of 11
Only if it is first order. If it is second order or higher the entire crossover topology will be AFU, as will be the results.
