AVS › AVS Forum › Home Entertainment & Theater Builder › Theater Room Items & Accessories › powered recliners... extension cords?
post #1 of 10
Greetings All,
I purchased 4 home theater chairs, they each recline but have individual power cords. I would like to avoid having to connect them individually to the wall.
I think this should be simple, but would/could I just buy a few short extension cords,
to connect them to where only the last chair would actually be connected to the wall plug?
I was thinking something like this:
http://www.monoprice.com/products/product.asp?c_id=102&cp_id=10228&cs_id=1022801&p_id=5289&seq=1&format=2
Just wondering how you all do this kind of arrangement... thanks!
JC
post #2 of 10
How long are the cords on the chairs?
Why not just run a single power-strip to hide under one chair and plug all 4 into that, worked fine for me.
 http://www.monoprice.com/products/product.asp?c_id=109&cp_id=10907&cs_id=1090702&p_id=9199&seq=1&format=2
post #3 of 10
perfect... I knew it was something simple... must get caffeine fast .... thank you sir!
post #4 of 10
You could get a black power strip (less visible) with a cord up to 15' long if needed.
and a six outlet unit will have a couple spares to plug in a tablet/laptop charger chord or a small adjustable task lamp...
I put one of these right behind my primary seat... $10
http://www.ikea.com/us/en/catalog/products/20169658/
JANSJÖ LED work lamp IKEA Uses LEDs, which consumes up to 80% less energy and last 20 times longer than incandescent bulbs.
post #5 of 10
This is really cool.. thank you! the wife has an Ikea credit that I never thought I would tap into... well I'm now!
by the way I saw the skulls on your profile... I saw similar ones (if not identical) at a korean tacos food truck the other day.. tequila right?
post #6 of 10
Yes, KAH Tequilla  http://www.kahtequila.com/ in hand painted collectable bottles
Edited by PioManiac - 4/25/13 at 12:43pm
post #7 of 10
post #8 of 10
Here's a shot of my IKEA task light, (sitting at the back of my arm rest)
Pretty handy when you have a very dark cave and don't want to turn all the lights on in the middle of a movie
post #9 of 10
I have an extra one of those IKEA lights collecting dust in a closet. I like this idea cool.gif
post #10 of 10
I think I'm hitting Ikea this weekend as well.. thank you for your help... I really appreciate it!
