AVS › AVS Forum › Audio › Receivers, Amps, and Processors › Marantz and Dual Subwoofer Hookup
post #1 of 2
I need help. I just purchased two subwoofers (SVS PC12-NSD's) and hooked the subs up from the Marantz AV7005 preouts using the SW1 to one sub and the SW2 to the other sub but from the SW2 preout I am not getting any sound via test tones or Audyssey set up. I'm sure I am missing a menu item that allows you to pick dual subs but for the life of me I can not find it.
Any and all help would be greatly appreciated.
Ted
post #2 of 2
Have you tried switching the sub cables from sub 1 to sub 2? Are you using the rca or xlr connections? You might have a bad sub cable or connector.
