AVS › AVS Forum › 3D Central › 3D Tech Talk › New to 3d trying to figure out what's wrong.
post #1 of 3
I have an Epson 3010 projector, a panasonic BDT230 blu-ray, a high speed 3d rated hdmi cable, and universal G5 3d glasses, tried a few others also. Bought Hobbit 3D blu-ray. The 3d just doesn't seem right. Anything that's supposed to be close has a blurry gohst look to it. also it almost seems like at times the things that are in the back seemed to be in front of things that should be closer. I don't know what I'm doing wrong. I've tried running the hdmi through my receiver and directly connected to the projector with no change. Would appreciate any suggestions.
post #2 of 3
Try turning the glasses upside down and see if that fixes it. If it does, then you need to reverse the L-R setting so that you you turn the glasses back the right way.
post #3 of 3
Well not at home right now to try that but I did use the feature in the Epson 3010 menu to invert glasses. It didn't help. I assume that's what you're referring to.
  Back to Forum: 3D Tech Talk
