AVS › AVS Forum › Audio › Audio theory, Setup and Chat › I think I need to angle my center speaker up - any recommendations on something I can use to angle the speaker up?
I think I need to angle my center speaker up - any recommendations on something I can use to...
post #1 of 4
I may get this...
http://www.thefoamfactory.com/acousticfoam/accessories.html
The second option to be able to angle my center speaker up. Should be good enough?
My set up is below. I was hoping to put the center speaker at the top level of the stand but I realized that mounting the TV would make it too high given the short viewing distance. I figure if it's going to be at the second level after some re arranging that I will need to angle it up.
tv.jpg 180k .jpg file
post #2 of 4
They should work if you know 4 degrees will be the ideal angle to point the drivers at your listing position. A slightly more flexible (and more expensive) option is to buy a package of Auralex MoPads, which have a 4° wedge and two smaller 2° shims.
post #3 of 4
Go for it, if they need a bit more angle, find something to add additional elevation.
I've got a set of four MoPads and they're fine, ... the foam shown would work just as well.
post #4 of 4
I think these may work well for you because the tilt angle is adjustable
http://www.nextacoustics.com/mofo-rizer-monitor-isolators/
I own a pair and am very happy with the results. they are substantially thicker thicker than the Auralex alternative
Edit: there is a special for the raisers. http://www.nextacoustics.com/mofo-rizer-sample-kit/
Edited by zheka - 4/26/13 at 1:53pm
