AVS › AVS Forum › Display Devices › Display Calibration › calibration toys help
post #1 of 3
Hello
I would like to buy some equipment calibration for my projector- sony hw10 , could you help me to pick up one of the cheaper and aswell good onee ?
I Was think about this one xrite i 1 dispaly 2, what do you think guys?
http://www.amazon.com/gp/aw/d/B000JLO31M/ref=mw_dp_img?is=l&qid=1366963461&sr=8-7
Thank you for help
Edited by anxion - 4/26/13 at 6:20am
post #2 of 3
Greetings
Cheap is cheap ... but good is a relative term. (Cheap is too of course)
That device isn't really designed for projectors ... and its accuracy is suspect.
Consider the d3 probe. I1 Display 3.
Regards
post #3 of 3
thanks for Replay
I will buy this one X-Rite ColorMunki Display i hope it will be good
