AVS › AVS Forum › Video Components › Home Theater Computers › HTPC Keyboard suggestions
post #1 of 10
First off let me state I have read the other threads on this topic here and most are well over a year old.
I do have a Dinovo mini and honestly I hate it. Keys are too small, but my biggest complaint is it keeps disconnecting from the PC, even though the dongle is just a few feet away.
I am going to try an Android app on my Nexus 7, but the issue with that is I won't always have it with me at the couch.
My goal is to find something between the Dinovo mini and a full sized keyboard in size that is wireless, has a trackball / mouse is reliable and doesn't cost a fortune.
Mark
post #2 of 10
The Logitech k400r is ok just don't try and use it with the signal passing through your couch or any other big objects,.
The keys are laptop style. It has a trackpad that supports limited win8 gestures.
Personally I love this keyboard as unlike a mouse or trackball when it is bumped it don't move the cursor and thus bringing up the hidden ui controls of whatever media player you happen to be using.
post #3 of 10
A keyboard is a must for any PC although I've found I'd worn out several RF keyboards/mice just starting my media applications!  To that end I found in Win 7 you can "pin" an app to the toolbar and trigger it with the "Win-#" shortcut on a Harmony remote using the Microsoft Media Center SE as a device!  No more grabbing the keyboard to start my media apps... I only use it when surfing and have a wired one in my EQ room for any real work.
post #4 of 10
Does fullsize mean a desktop with numeric keypad?
If so, then this one from iogear is smaller than fullsize and won't break the bank.
http://www.geeks.com/details.asp?InvtId=GKM581R-PB
post #5 of 10
I just bought this keyboard today. I think I am going to love it. This is one remote control that I will not have any problems finding.
post #6 of 10
+1 for the Logitech K400.
post #7 of 10
How is the wireless range ?
post #8 of 10
Another vote for the K400. The only thing that I don't like is the right Shift key...worthless.
Range-wise, I sit 12-13 feet away, and experience no problems. I have the receiver plugged into front USB port. Works great for the occasional times you need a real keyboard.
post #9 of 10
I've tried it at 20 feet & it still works.
post #10 of 10
While it has great range, I couldn't get screen word FONT large enough to justify staying as far back as I can.
