AVS › AVS Forum › Audio › Home Theater In A Box › HDMI Arc - help noobie girl
post #1 of 2
I'm new here and new on surrounds sounds.
I have following that I can't get to work:
TV: Panasonic GT50
Surround: Samsung HT-F6500
I would like to use the sound played on my TV to get through my surround set with HDMI arc but what should I set these devices to in the settings?
post #2 of 2
TV: Panasonic GT50
http://www.samsung.com/uk/support/model/HT-F6500/XU-downloads#
Connecting to a TV
Connect an HDMI Cable (not supplied) from the HDMI OUT jack on the back of the product to the HDMI IN jack on your
TV. If you have set the product's remote control to operate your TV, press the
TV SOURCE
button on the remote control
and select HDMI as the external source of the TV
http://service.us.panasonic.com/OPERMANPDF/TCP60GT50.PDF
see page 17
eHELP (built-in manual) helps you understand how to easily operate the TV features by pressing the HELP
button
http://service.us.panasonic.com/OPERMANPDF/E-HELP_GT50.PDF
see page 132
Connecting Home theater system/AV amp
HDMI and Audio connection.
Connect the HDMI terminal and DIGITAL AUDIO OUT to Home Theater System/AV
amp with VIERA Link function using each fully wired HDMI cable and Optical audio
cable.
HDMI 2 is recommended.
No optical cable is necessary when connecting a Home Theater supporting
"HDAVI control 5" with an HDMI cable.
Audio will be supported via ARC (Audio Return Channel)
One AV amp and one Blu-ray Disc player/DVD recorder (DIGA) can be operated
with this unit by connecting with an HDMI cable.
  Back to Forum: Home Theater In A Box
