AVS › AVS Forum › Audio › DIY Speakers and Subs › Remote triggering an amplifier on an Onkyo amp without zone 1 12v trigger
post #1 of 14
I thought I'd share my idea with you all incase anyone else wants to do the same. I have wiried up a SSR (solid state relay) into a metal box to be used as a 12v trigger for my Onkyo 818 receiver, however my receiver only has triggers for zone 2 and 3. I don't really like the idea of having to do extra button presses of having to select zone 2 (or 3) with the remote, then hitting the power button to turn on the sub. Same thing for turning it off. This partially defeats the point of having a remote trigger because I may forget to turn the sub on or off.
I looked at my receiver for anything that had switched power and the USB ports (front and back) stood out to me. They both turn on and off with the receiver so I am going to use them to remotely trigger my SSR. USB provides 5v and my SSR only needs 3v, so everything should be fine.
The only issue I see, however it won't affect me, is that turning on the receiver's Zone 1, 2 or 3 turns on the the USB ports. This means that if you use zone 2 or 3 for another room, the sub would turn on. I don't use those zones so that isn't an issue for me.
I plan on swinging by radio shack to pick up an 1/8" male connector and taking a mini or micro USB cable and hacking the 2 together soon, I'll update with how it works, however it should work fine.
Nathan
post #2 of 14
If that doesn't work out for ya, can always use my favorite of hacking a atx pc power supply. Have it just come on when you power on your receiver and it will feed 12v, 3.3v, or 5v to anything needed.
To have the power supply come on outside with it you could have it on the same switched source as the receiver like one of those switched power strips. To make the power supply come on with plugged in power just open it and twist tie the green wire to a black ground. Makes it always on when plugged in and switched on.
Can't believe onkyo triggers don't feed or strap to zone 1. What's the point lol. I mean didn't they think you'd at least have a projector and maybe a screen in your main viewing area....what a joke biggrin.gif
post #3 of 14
I didn't make it out to radio shack so instead, I just hacked 2 wires in half and soldered them together. USB type A on one side and 3.5mm headphone on the other.
It worked fine. This simple trick adds a 12v trigger to receivers that have USB ports, but only if the USB powers on and off. Well, thats not true, it added a 5V trigger to my receiver. I could now take a 12v power adapter or wall wart and plug it into my SSR (relay) to give me a true 12v switched trigger source. but that isn't needed for me.
Likewise, I could also use one of those smart power strips. The problem with those is that most people would plug their sub amps directly into it. If you have a very high wattage system, that isn't going to work well. That means you are drawing power for your receiver, and sub amps from the same outlet/breaker. I could potentially use a smart power strip and a 12v wall wart to trigger the amplifier relays. This would allow the subs and other triggered devices to be on their own outlets and breakers.
It is hard to believe that they can't get that simple feature right...
What are your doing that you need 3.3, 5 and 12v?
post #4 of 14
That is a good idea using the 12V power adapter in the smart strip to trigger the relay or using USB. Then the amps could be on a different outlet if you don't have a 12V trigger on your receiver. I am looking at getting an Onkyo 818 and was planning on using the 12V triggers for this purpose. Good to know ahead of time that wouldn't have worked and that you found a solution, thanks.
post #5 of 14
Well I needed more than the standard 12V trigger could provide from the receiver when driving multiple relays (75ohm@12vdc). Also like you couldn't have all my gear sharing power strips.
Here's a peek at my rig. > > > post_23197038
post #6 of 14
Not trying to hijack, but I am searching for ways that I could power on my entire system for watching movies, powering up all components at once, preferably from my Denon's remote, or my iPad, or my iPhone. Here s what I have as far as components go:
Denon AVR-3312 (receiver)
Sony BDP-590 (bluray player)
Behringer EP-4000 (sub amp)
Mitsubushi WD-60735 (tv)
Any Ideas on how to go about doing this? I also have a cable box, an Art Cleanbox, and a ARRIS modem. Any opinions, or advise would be terrific!
post #7 of 14
belkin (if i'm not mistaken) have a power distributor/power strip that have the ability to be wired to your ARV 12V trigger. it accepts a trigger input from a remote equipment and turn on all the other equipment connected to it.
post #8 of 14
What are you trying to accomplish? It seems like you want a 1 button solution to turn everything on, is that right? Also, are you trying to turn off the cable modem when you shut down the system?
I just searched and only found the Belkin PF60 to have that feature from Belkin. If that is the main reason to own a device like that, a DIY switchbox can be made much cheaper with a SSR or a normal relay and a metal box.
post #9 of 14
not everyone is comfortable dealing with AC line and solder irons.
post #10 of 14
I agree that not everyone is comfortable working with electricity. I am glad of that because many people should not attempt to do so.
I just found a device that is reasonably priced and is controlled from an external voltage source of 4 - 24v. http://www.smarthome.com/43998/Bits-Limited-LEG3-Energy-Saving-Smart-Strip-with-Volt-Sensing/p.aspx
A review on Amazon stated that someone hooks it up to his receiver's trigger. The picture is confusing though, but the description definitely states that it uses a trigger.
post #11 of 14
Definitely interested in this. Might need a little one on one time, so you can walk me through the details man.
post #12 of 14
Just a comment about the smart power strip (at least the one I tried) is that when I tried using one with my 1008 it just stayed on all the time. I think that may be related to the fact that I have RHID turned on, but I'm not sure....
I also had a bunch of equipment to turn on that needed more than a single circuit, so returned the smart strip and I ended up using a current sensing relay that turns on an outlet that I have a 12v wallwart plugged into. That in turn powers on a set of 4 30A (4 20A circuits) relays to turn on all my power strips. These power up all my amps and electronic xovers.
I have a post somewhere around detailing how I built it....
I do like the USB idea though... I may have to see if I can get that to work with my relay.
post #13 of 14
any updates ?
post #14 of 14
Originally Posted by Bombelman View Post
any updates ?
Who are you asking for updates from? I have been using the same setup since I originally posted, so apparently about a year now. No problems with my SSR or anything else. I can take mine apart and show the guts if someone would like me to.
Nathan
