AVS › AVS Forum › News Forum › Community News & Polls › Which Setup Disc(s) Do You Use?
Which Setup Disc(s) Do You Use? - Page 3
Poll Results: Which Setup Disc(s) Do You Use?
This is a multiple choice poll
  • 10% (50)
    Avia Guide to Home Theater (DVD)
  • 22% (112)
    AVS HD 709 (HD download)
  • 41% (203)
    Disney WOW (Blu-ray)
  • 3% (15)
    Disney WOW (DVD)
  • 6% (31)
    JKP Digital Video Essentials (DVD)
  • 20% (99)
    JKP Digital Video Essentials: HD Basics (Blu-ray)
  • 1% (6)
    Monster/ISF HDTV Calibration Wizard (DVD)
  • 23% (118)
    Spears & Munsil High-Definition Benchmark (Blu-ray)
  • 2% (12)
    Sound & Vision Home Theater Tune-Up (DVD)
  • 11% (56)
    THX Optimizer (on THX-certified Blu-rays and DVDs)
  • 5% (25)
    Other
  • 8% (40)
    None
495 Total Votes
post #61 of 79
Originally Posted by tang7969 View Post
Sell it. I'll buy it!!
If you had bought it thru amazon then, you'd be getting it tomorrow just in time to play with it over the weekend tongue.gif
post #62 of 79
I did a lot of searching reading reviews about the various calibration disc and settled on the Blu-ray version of Disney's WoW. I used it on my HDTV and had great results. But then I used it on a cheaper plasma Samsung my friend had and didn't seem to be able to make much improvement over the settings I had made previously with the friends TV. This is the only calibration disc I have tried as I am a rookie at this. Also am I to understand correctly that I should re-calibrate every few months? Thanks and enjoy reading the posts here. smile.gif
post #63 of 79
I hesitate to participate in this discussion, since I obviously am biased. smile.gif
One advantage to the Spears and Munsil disc is that both of us are long-time AVS Forum members and you can ask us questions directly. As to which are easier to use, other folks can make that determination. I will say that on this 2nd edition we tried to make it much easier for a novice to figure out how to use the disc and get a good calibration.
And whether you buy our disc or not, the articles on calibration on our web site are free and generally apply to using any disc (though obviously the screen shots might not match up exactly). Drop by and take a look if you're interested:
http://www.spearsandmunsil.com/2nd-edition-articles/
post #64 of 79
S&M - Too bad you couldn't have come up with a cute Red Head like on the DVE Blu-ray! A Rabbit - you got to be kidding! (Yes, I was one of the first to buy #2.)
OK, I get it - you need 4K to enjoy the Rabbit properly! (Plus the Montage)
Still, it would have been nice to have a cute Redhead!
Tried to find one to post, but all roads led to where you don't want to go to!
For those with the DVE Blu-ray, and haven't seen the Red Head, then you have to do some digging - uh, I mean clicking!
Edited by p5browne - 5/16/13 at 5:00pm
post #65 of 79
Originally Posted by dmunsil View Post
I hesitate to participate on this discussion, since I obviously am biased. smile.gif
I love both of your disk, thank you very much for all of your hard work!
Also as a Seattle resident I enjoy the scenes of my neck of the woods in the disk.
Edited by PlayNice - 5/10/13 at 9:47pm
post #66 of 79
Hi dmunsil!
I was hoping you could provide some more detailed description of the A/V sync tool on your new disc. How does it work, exactly? And do you also have a simple beep+flash movie on the disc? If so, does the whole screen flash? I own a Syncheck device (great geeky tool!), but one of my frustrations with my DVE Blu-ray disc is that the one flash+beep pattern on their disc only flashes a small sliver of the screen in time with the beep. This doesn't work very well with my projector, in terms of getting the flash reliably detected by the Syncheck. Of course, I can also play back custom files from a USB drive or computer, but I've run into the fascinating (and frustrating!) phenomenon of my receiver yielding distinct A/V sync results when dealing with Blu-ray movie content vs. other sources. Specifically, the audio from Blu-ray movie sources tends to get hugely delayed (100ms or more) when the video and audio are heading to my receiver together via HDMI (I've compared this to audio sent via optical cable, which is not severely delayed, and neither is audio from non Blu-ray movie sources even when sent over HDMI). Whatever the reason, I'm hoping the S&M v2 disc has a basic beep+flash pattern that flashes the whole screen so I can get a more reliable Syncheck measurement that I can use with my standard library of Blu-ray movies. It would be interesting to compare this to whatever measurement I get from your disc's built-in sync tool.
post #67 of 79
HI, welcome to AVS !
You'll love the Wow BD !
Plasmas can change over time, especially in the first few hundred hours - 500 hours +.. I'm pretty sure they can still fluctuate after that also. So yeah, it would be good to check and re-calibrate as necessary once in a while.. shouldn't take too long and you'll get really efficient at it tongue.gif
post #68 of 79
Originally Posted by Mischaflix View Post
Hi dmunsil!
We don't flash the whole screen, but we do flash the top and bottom. I'm not sure if that will work with a SynCheck, but the intent was to make it work with automated synchronization checkers. It should produce a pulse on the video signal, and if you're using a light meter aiming at the top or bottom should work well.
Our sync check pattern has a little of everything. There's timecode, flashing the top and bottom of the screen, a stylized clock indicator, and a bouncing or scanning marker. There are patterns for 24p and ones for 29.97 with 2-3 pulldown.
post #69 of 79
You're quite welcome! The shots of Gasworks Park were fun to shoot, though the wind was shaking the cameras like crazy. Stacey was able to de-shake the video and now it looks pretty serene. If you look at the corners of the screen, though, you can see some of the shaking leaking through. smile.gif
post #70 of 79
I have used the Pixel Protector on my 2006 Pioneer. My family rarely used the zoom feature when all the commercials and shows broadcast in 4:3 and I did suffer black bar burn in. I contacted Pioneer and they advised to use the above disc. It did help even though it did not eliminate. I also used it on a spare bedroom low priced lcd/led that had terrible colors, and it really did improve the picture quality. I was amazed it actually worked.
post #71 of 79
Pixel Protector Blu-ray Washes are the Best: 6 Hours for the First Wash, 2 Hours for the Second and 1 Hour for the Third. Then shut your set off for a couple of minutes. Turn back on, then on to watching improved appearance TV, or start your calibration.
post #72 of 79
Walmart has two different BluRay Disney WOW disks. It looks like one has more audio formats and was released more recently. Any preference of one or the other?
post #73 of 79
The only versions I'm aware of are:
- 1 disc version
- 2 disc version
The second disc is only HD display material.
Are those the ones you're taking about here ?
post #74 of 79
post #75 of 79
Here are the links. The second one looks best to me. What do you think?
http://www.walmart.com/ip/Disney-WOW-World-Of-Wonder-Blu-ray-Widescreen/15184078
http://www.walmart.com/ip/WOW-World-Of-Wonder-Blu-ray-Widescreen/20462075
Yeah the 1st link is the 2 disc set, you don't really need this unless you want that 'HD landscape BD. The second link is the one disc, and that's all you need really. I would get that one, price is better too smile.gif
post #76 of 79
Just received Spears and Munsil 2nd Edition. Let me tell you guys it officially ROCKS!
Stacey Spears and Don Munsil will be guests on my podcast this Monday to talk about the new disc. Watch live on 5/13 from 2 to 3 PM Pacific time at http://live.twit.tv, where you can join the chat room (or at http://irc.twit.tv) and post questions for Stacey and Don.
post #77 of 79
post #78 of 79
Dang, right during my working hours!
post #79 of 79
You can always catch it after the fact at http://twit.tv/htg or http://YouTube/TWiTHomeTheaterGeeks or here on AVS. The show is usually posted on Tuesday.
  Back to Forum: Community News & Polls
