AVS › AVS Forum › Audio › Receivers, Amps, and Processors › RX 773 air play connection (UK) issues with YMA 10 and BT Home Hub 3 issues
post #1 of 4
Hi
I've just bought a Yamaha RX 773 - sounds fantastic, connects brilliantly with all my HDMI devices via the ARC channel and my phono deck/analogue ipod/cd optical connections. My problem is that I discovered there is no internal wireless network connection with this unit. No problem, I buy the Yamaha YMA 10 wireless connection device. After a while, following the instructions, I connect said device, checking it's working properly by disconnecting the wireless on my macbook pro and connecting the device via the LAN socket - I can get full network and internet connection - and then connecting the YMA 10 to my RX773 via a cat 5 cable and checking the Network Info tab - yes, its connected fine. I then run the internet radio function - works fine - then run Airplay on the amp and then start my iPhone 5 then my iTunes on my Macbook Pro - again, works fine. I then turn the unit off for a couple of hours, come back and turn everything on. I wait for a minute and try and run Airplay from my phone - no connection. Try resetting my router (BT Home Hub 3 for UK readers), no good. Only after unplugging and replugging YMA 10 unit and router does it finally work. Surely, it shouldn't be like that. What am I doing wrong? Is it unreasonable to expect several hundred pounds worth of kit to wirelessley connect again once I have got it to work following Yamaha's instructions?
Router is WPA/WPA2 AES encription. The Amp seems to connect thorough the network no problem, even if Airplay isn't working. GGGGRRRR!
post #2 of 4
Originally Posted by slarn View Post
Hi
turn off network standby mode...you wont be able to turn the avr on with the mobile app but it will fix your issue. i have contacted yamaha about the bug and you should too. hopefully they will release a firmware update to address the issue.
post #3 of 4
Have done this, and it appears to have fixed the issue, although the Yamaha remote app on my iPhone 5 doesnt want to work, however that's not a biggie. Thanks for the help, Mark:)
post #4 of 4
