IR Remote Lights
post #1 of 6
Does anyone know of any LED puck lights or perhaps strips that work off of an IR remote? Links would also be helpful.
post #2 of 6
Anyone?
I'm looking for a light that can be hardwired in to a wall since I have no room for soffit at the bottom of the wall for walking lights.
post #3 of 6
http://www.ebay.com/sch/i.html?_nkw=led+light+strip+remote&_sacat=0&_odkw=led+light+strips&_osacat=0&_from=R40
something like this?
I need to figure out if I do a crown molding in the room, mounted an inch or so down from the ceiling with these in there or not.
post #4 of 6
Does anyone know if these can be hard wired? I want the cords and everything to be out of sight and not just simply plugged in to a wall outlet.
http://www.amazon.com/Waterproof-Strips-Remote-Controller-Power/dp/B008YRZ9YS
post #5 of 6
Anyone?
post #6 of 6
I bought a little remote control plug in module at Home Depot at Christmas time that was meant to plug a Christmas tree into. I have a couple spot lights behind my acoustically transparent screen that light up my center speaker. I did not have extra space on my Grafik Eye to control this so I just did it with this simple $9 solution at Home Depot.
It looks something like this.
http://1000bulbs.com/product/59658/CMS-ODHOLREMOTEGRN.html
