AVS › AVS Forum › Display Devices › LCD Flat Panel Displays › how do you do 2d to 3d conversion?
post #1 of 6
We just got a sharp 80'' 3d tv and we were playing an xbox game and wanted to use the 2d to 3d conversion. we went to the menu for 3d but on the 2d to 3d conversion option it has something like a cancel sign on it( like a circle with a line going through it) and it wont even let me select it. when i try to scroll down onto it in the menu, it just skips past it and goes to the next option. Can someone please give me some advice on how to fix this please?
post #2 of 6
Just a guess -- 3D is not available with that input...
post #3 of 6
thats not what i mean. the whole point of the feature is to turn non 3d images 3d right? and i wont let me
post #4 of 6
He's saying that only certain inputs will let you do that. Perhaps only the first hdmi port will do it. Or maybe you can only do it on hdmi and not component.
And I would advise not to do that for games anyway. You will get way too much lag.
post #5 of 6
i have it on an hdmi input and its the same input that lets me do the active 3d feature in black ops. i don't mind the lag because the 3d is so fun, but i want to play the halo campaign in 3d but it has no 3d settings. i have 4 hdmi inputs so should i just test them all out?
post #6 of 6
What model 80" do you have?
If it has game mode and you are using it most like you can not do 2d to faux 3d at the same time due to all the processing required.
