AVS › AVS Forum › Display Devices › Rear Projection Units › Mitsubishi WD60C8 Image Alignment
post #1 of 2
I bought a DLP TV WD60C8 off Craiglists that wasn't working. I took it all apart and cleaned the optics and replaced the lamp. Now there is a Black Bar at the top of the screen where the image is not projected. I went into the service menu to move the image but the black bar never moved so I am assuming this is an optic alignment issue. Any help?
post #2 of 2
Rebuild and reinstall the light engine. Others have had this problem. Search the forums, the procedure is there somewhere.
Edited by Augerhandle - 5/1/13 at 10:17am
  Back to Forum: Rear Projection Units
