AVS › AVS Forum › HDTV › Local HDTV Info and Reception › No reception
No reception
post #1 of 5
I have always received great local reception for channel 6,6.1,6.2, 6.3 ,8 and 12.3, 23.1, 23.2, 57.1, 35.1, 35.2 but as recent as a couple of months ago the picture for certain channels on my TV begin to break up ( little squares would appear, like the ones when I run my microwave). Then reception just stopped. Now I get "no signal" for channel 6, 6.1, 6.2, 23.1,23.3 and 57.1. Any ideas why this would be? I use a very good attic antenna that has not changed. I have check the wire and it is the same.
post #2 of 5
It may be a good time to do a channel scan once again. Some of the channels that you have listed (6 & 8) are no more. Others may have changed frequencies since your last scan.
Since the signal degraded and quit, I'd look for a connection that has come loose, or possibly rodents chewing through your RF cable.
post #3 of 5
Guessing you're in Richmond, VA. Those stations were involved in an on-going equipment failure situation and are at reduced power.
The Richmond thread will give you more information.
- Trip
post #4 of 5
How do I get to the Richmond thread?
post #5 of 5
