AVS › AVS Forum › Display Devices › Digital Projectors - Under $3,000 USD MSRP › Weird green color issue with two different InFocus projectors.
post #1 of 4
Originally I had an InFocus IN26+ business type XGA DLP projector. For some strange reason, no matter the settings, the greens were too bright. Greens that you might see in, say, the green grinning smiley >>> biggrin.gif <<<< would be flourescent / neon green looking. Obviously brighter than the rest of the colors around it.
I had it hooked up via VGA to a computer, and no matter the color space or temperature it would do this.
2 months ago I bought an InFocus X10, 1080p, home theater DLP projector - refurbished - on eBay.
It has the exact same green color issue. It is hooked up via HDMI to a computer also, but this computer is also new. I can resolve the issue by turning on brilliant color. However, any setting (as before) without brilliant color will have the green issue.
Is this a symptom of a bad color wheel? Or bulb? or what?
I will upload pictures soon to make it obvious what I mean. Thanks for any help.
post #2 of 4
Ok here is a hue/saturation test chart I use that makes it obvious.
Here is the original chart image:
Here is the issue, the horizontal bars are supposed to be darker than the foreground - not brighter.
And with BrilliantColor turned on, all the other colors remain normal as they were, and green becomes normal, too.
post #3 of 4
I'm not expert and can't interpret color charts, but quite a few of the DLP projectors I've come across push green. In the case of LCD, I find they often push red. As in your case, this can typically be solved with calibration and messing with settings.
post #4 of 4
To me when I hear DLP color push I think of some vague miscalibration that an average joe couldn't see without a side by side comparison.
This seems more glaring.
IMHO anyways.
