AVS › AVS Forum › Audio › Receivers, Amps, and Processors › Voltage drop?
Voltage drop?
post #1 of 3
Hi Everyone,
Sorry if this is a repost, but I'm contemplating using external amps with my receiver and I was wondering if anything has to be done to the electrical system.
For example if I currently have my subwoofer, receiver, HTPC and TV plugged into a power bar, would I need to get any additional equipment in order to run a 5 channel amplifier as well? Any help would be appreciated...thanks!
post #2 of 3
I'm no home theater geek but I am a retired electrician. Don't worry about voltage drop in normal household usage.
post #3 of 3
Ok that is exactly what I wanted to know. Thanks very much!
