AVS › AVS Forum › Audio › Subwoofers, Bass, and Transducers › Sub Recommendation
Sub Recommendation
post #1 of 6
I am putting together my HT system. So far I have firmly decided on the Denon AVR-2313 CI, and the PSB Image T6/C5 for the LCR. Need help on matching up a sub woofer around the $500 range. The set up is going in the great room. About 70% movies and 30% music. I will be installing ceiling speakers for the rear. Thanks for your feedback.
post #2 of 6
spend 100.00 more and get 2 klipsch rw-12's. right now they are 299.00 shipped each. great sub for the money and two of those would be better than one 500.00 sub imo.
post #3 of 6
I just checked Newegg, and the price is $349. Where is the $299 price?
post #4 of 6
Subscribe to NewEggs eBlast newsletter as that's where you'll find the discount codes. I just got the RW-12D for $279. I believe the $70 off coupon expired on the 24th. Be patient as NewEgg is constantly discounting this sub.
post #5 of 6
In your opinion, is going with 2 Klipsch better than going with 1 better sub ($500 range) based on my room?
post #6 of 6
Outlaw LFM EX should also be a consideration, if budget is tight at $500 yes two rw 12s is the way to go
