AVS › AVS Forum › Audio › Soundbars › Looking for help/advice. Budget: $300 Needs: Connect HDTV/DigiCable Box & HTPC
post #1 of 3
I know almost nothing about audio system but I believe a soundbar is my best bet for upgraded sound from my built-in speakers within my 50" Sammy plasma. My only concern is I won't be able to find something that is able to connect to my HTPC, and my Wii (if possible, but no biggie).
Is there something out there around $300 that sounds decent and can connect to an HTPC? Other than a sound bar, are there any other options I could look into?
Thanks in advance for any an all help!
post #2 of 3
How exactly will you be connecting everything to the soundbar? HDMI? From all sources?
post #3 of 3
HDMI was the plan. Sorry for delayed response, life is quite hectic currently.
  Back to Forum: Soundbars
