AVS › AVS Forum › Display Devices › Screens › how to fix wavy lines on screen bottom sections
post #1 of 3
Greetings,
I was wondering if you had encountered issues with wavy lines with elite screens? It has been hung for a while
but just recently started to notice wavy lines at the bottom. More visible when watching programming with scrolling
text like espn, etc. Movies look ok...
Anyways, its a pull down screen. I was wondering if you had seen or experienced any fixes with velcro, as I can leave the
screen down and "attach it" to the wall etc..
I guess I'm just looking for suggestions?
JC
post #2 of 3
Do a forum search "Waves" or Screen Waves" or Elite Waves.. you will find lots of people with the problem but there is no fix other than replace the screen with a tab tensioned screen..
post #3 of 3
  Back to Forum: Screens
