AVS › AVS Forum › Blu-ray & HD DVD › Blu-ray Software › AVS Can't-Wait Special—"Mastered in 4K" Blu-Ray Releases
AVS Can't-Wait Special—"Mastered in 4K" Blu-Ray Releases - Page 28
post #811 of 825
Originally Posted by helvetica bold View Post
Geoff which test pattern are you using for x.v.Color? I have the 2nd edition disk and I would love to test the PS4 on my new Sony display. I thought there wasn't a test pattern
ftor xvColor. But if there is I would love to know.
I forget the name of it, I'll check it for you later.
post #812 of 825
Thanks Geoff
It here's a thread on BluRay.com where Stacy Spears posts and she said you can't test for xvYCC on the disk.
Below is her response.
"xvColor is not officially part of the BD Spec, so there was no way, at the time of authoring, to signal it.
Most displays have xvColor disabled in the TVs UI if its not present. You can check and see if they enable it when you are playing a know title that claims to support it. At least my Panasonic VT20 was like that."
post #813 of 825
Thanks Geoff
FYI, Stacey is a "He".
post #814 of 825
HA, thanks Milt!!
noted!
post #815 of 825
Thanks Geoff
I could be wrong, but I get the impression from Stacey's response that the test pattern itself is genuine but it doesn't 'signal' the display in any way to tell it that it's passing xv colour. I have to actually turn it on in my TV menu to get the xvYCC pattern to display properly.
BTW it's under Advanced Video -> Evaluation -> Clipping.
post #816 of 825
I just watched the newest "ROBOCOP" and I have to tell you that it is a step up in clarity, but is it worth the $8 to do so??? Yes, it is and it will fit perfectly with all the other copies of the same movie...the only one I don't have anymore is the LD...time ,to move on, as they say!
post #817 of 825
Thanks so much Geoff! I'll give it a try. I'll manually set my W9 to xvColor. I have Captain Phillips to watch on my PS4 but don't know if if will output xvColor. Even if it does the difference might not be noticeable.
Edit: I ran the clipping pattern you are correct! PS4 will output x.v Color!
Unfortunately the Xbox one will not. In fact the Xbox one video output is a mess.
When RGB full is selected it clips the color range. If I'm describing it correctly.
All the boxes were solid viewing that pattern. If I set it to limited then it displays correctly.
That makes no sense to me. PS4 worked perfectly with RGB full.
Edited by helvetica bold - 2/10/14 at 8:55pm
post #818 of 825
The Smurfs 2 Blu-ray, mastered in 4K by Sony, is possibly the best-looking Blu-ray I've ever seen.eek.gif And trust me, I have seen too many to count. I have never seen live-action video blended so well with CGI, including Avatar. This is the definition of pure eye candy.
post #819 of 825
If Smurfs 2 had Kate Upton and Scarlett Johansson naked and making out with each other there still wouldn't be enough eye candy to make me watch the rest of it.
post #820 of 825
Duly noted...
post #821 of 825
To draw it into an actual point though, it would easier to get excited about 4k (both true 4k and these Mi4k titles) if more of these were actual, you know, good movies. Glory, sure. Captain Phillips, Taxi Driver. Most of these others are just garbage though. This is seriously how Hollywood wants to turn people on to this new format? By using it to squeeze a few more bucks out of a bunch of CGI craptaculars and pointless remakes?
post #822 of 825
This is the same thing Sony did with SuperBit DVDs. The mentality from the studio is that the new branding is a way to move some copies of properties that have otherwise gone stale. How else could Sony make any money off Johnny Mnemonic? Nobody's going to buy that title for the movie itself, but some suckers might pay to check out the whiz-bang "SuperBit" thing.
post #823 of 825
Who said anything about watching the rest of it? That's what chapter stops are for! smile.gif
post #824 of 825
post #825 of 825
I ordered Spider-man 3 4K which was released yesterday. I am hoping Walmart sends me the correct one.
  Back to Forum: Blu-ray Software
