AVS › AVS Forum › Home Entertainment & Theater Builder › Theater Room Items & Accessories › Star ceiling drop panels DIY HELP
post #1 of 3
hello all
Im looking to update my HT and would love to add a star ceiling. i'd used at least 2'x2' panels for my drop ceiling. I would need at least 6.
I have 2 questions.
Is a DIY project cheaper than just ordering a professionaly made panel? I have no idea what the materials needed cost. Fiber optic wires, twinkle mechanism, light box etc etc.
Can anyome please point me to the best DIY with step by step instructions on the forum?
On the website cinemashop, each star 2x2 star tile with fabric wrap and twinkle lights go for $180 EACH for a total of $1,080!
My wife would frown upon me spending that much.
But they make it look easy. even daisy chain them all together using a male and female plug.
Roughly how much would a DIY project cost? I should have the tools bTW
Any help would be GREATLY appreciated.
Thank you
post #2 of 3
You may be able to build them "cheaper" but it depends on whether or not you factor in your time as labor. You may also not end up with results as nice as professionally made panels.
You will need the following:
Illuminator(s): either one central illuminator or one small illuminator for each panel. The smaller illuminators make for an easier installation. You just pop the panels in and plug them together then you are basically done.
Rigid board
Fabric
Fiber-optic cables: it's best to use varying thicknesses for a more realistic look
Glue: to glue the fabric to the board
Tape: to keep the fibers organized and mounted on the underside of each panel
Some Tools you will need: Drill bit or another a way to cut the holes in the board. In our case we use an automated CNC machine that makes a counter-sunk type hole on the back side of the panel. This enables you to locate the hole much easier and makes inserting the fiber in the hole easier.
Scissors and/or cutting wheel for cutting the fabric
Knife to cut the board: An electric carving knife will work nicely depending on the type of board
Can anyone please point me to the best DIY with step by step instructions on the forum?
I have not seen a DIY on this forum so far, but I have not looked recently.
post #3 of 3
My star ceiling isn't made with tiles, but rather 3/4" mdf. the starfield is about 7.5'x16'. supplies alone were about $1000, the fiber an illuminators were the biggest cost. It probably took me a good 50 hours to construct and install and it is a tedious job. I'm very happy with the results though and I would do it again. However, if anyone else asked me to build them one, I'd charge way more than a grand just due to the time and hassle it is to build.
