AVS › AVS Forum › Blu-ray & HD DVD › Blu-ray Software › Inception Steel box question
post #1 of 4
I picked this up from BB for $9.99
When I opened the box- there is no booklet.
I mention this because the inside cover has booklet clips.
Should there a book with this version?
post #2 of 4
I have this steelbook as well, there's no booklet. The clips are just part of the case, just in case... wink.gif
post #3 of 4
Booklets? You're joking. Lucky if we get a pamphlet included, these days.
post #4 of 4
With SteelBooks, I usually fold the cardboard backer and store it inside the case under those clips.
  Back to Forum: Blu-ray Software
