AVS › AVS Forum › Display Devices › LCD Flat Panel Displays › Official Samsung UNXXF7100 Owners Thread
Official Samsung UNXXF7100 Owners Thread - Page 69
post #2041 of 4975
Originally Posted by matrix123 View Post
You should have kept the first one.
I was on the fence, but I decided to try to fix the lean issue by re-attaching the stand using the lay-down procedure Samsung recommends. Doing that caused a ton of banding/DSE, so the decision was made...
post #2042 of 4975
Damn. I installed mine keeping up right someone else helping.
post #2043 of 4975
These are the lines I am seeing. Hope whoever checks it out can see it.
post #2044 of 4975
post #2045 of 4975
post #2046 of 4975
Pictures taken on the menu and the hub
post #2047 of 4975
I can't really see it on the first 2 pics., I do see the lines on the 3rd pic.
I don't know what that is...maybe static electricity- a lack of a grounded circuit.
Could be a processing computation defect caused by firmware updating.
Have you done a factory reset?
post #2048 of 4975
I did a while ago when I first saw it. The third pic is of the hub and is different from what I see in menu. Do you see anything like that on your hub?
post #2049 of 4975
Factory set did nothing.
post #2050 of 4975
post #2051 of 4975
post #2052 of 4975
No it looks solid, no lines.
post #2053 of 4975
These two show more- it does look like very mild static electrical lines- due to improper grounding and power surges.
Could be interference as the HDTV does pick up over-the air signals.
post #2054 of 4975
Non of my others looked like this and had banding/lines I can see during movement. Ugh. Gonna replace it tomorrow. I'm on the silver rewards with best buy and have 60 days to return. It's only been about a month. WTF. He we go again. If it was a little bit I could deal with but it's from top to bottom.
post #2055 of 4975
Not for the Faint of Heart - the loading screen for the Explore 3D App.
post #2056 of 4975
When u bring up your standard menu, at the top where it's blue yours is solid right? without any streaks or lines?
post #2057 of 4975
Menu from D series:
http://reviews.cnet.com/flat-panel-tvs/samsung-un55d8000/4505-6482_7-34503721-2.html
Notice the top is lighter blue.
Same thing with the ES menu:
http://reviews.cnet.com/flat-panel-tvs/samsung-un55es8000/4505-6482_7-35118272-2.html
Lighter blue top line on menu.
Even the F series menu (on pretty awful pictures):
http://reviews.cnet.com/flat-panel-tvs/samsung-un55f8000/4505-6482_7-35576107.html
Notice the color gradient transitions.
http://www.televisioninfo.com/
Had better photos of menus to research....
post #2058 of 4975
I think you are making the right choice if other TV's had not showed this symptom being plugged into the same outlet. Better luck with the replacement!
post #2059 of 4975
No its not solid blue it has the color gradient of 8-bit color mentioned a few pages back.
Its always been that way from the D series, ES series and now the F series- see above post.
I know its difficult to stop looking for issues.
I've been there before...so I known how it can be.
#1 Realize that no HDTV is perfect.
#2 Every TV has "flaws" you won't notice for weeks, months or years later.
#3 Focus on the content not the idealized technical performance.
Then, again you may have a issue with the Smart Hub screen.
post #2060 of 4975
Boardwalk Empire on HBO really shows off the F7100's outstanding picture quality.
post #2061 of 4975
This is so true, I really have to agree with you on that, but I guess we all can get a little nervous when dropping a few grand on these TV's, oh by the way I reset to default settings from best buys calibration, the guy did maybe a half an hours work...not worth what they charge, or free for that matter.
post #2062 of 4975
Gotcha...my gut always told me the "free" Best Buy calibration was a waste of time.
Did you write down the settings of the calibration?
post #2063 of 4975
Firmware Version 1110 Notes have been released....
Drum roll please.......
1.This firmware is for TV Model(s): LED F5500/F6300/F6350/F6400/F6800/F7050/F7100/F7150, PDP F5500
2.The version is 1110.1
3.This firmware update will improve the following:
- Solves Network Connection Issue with Wireless Router.
- Improves Picture Quality.
- Solves the issue Screen Mirroring does not work.
- Solves the issue Digital Clean View does not work correctly.
Hmmmmmm...sounds very familiar.....wink.gif L.O.L.
post #2064 of 4975
I actually posted them, earlier, I through the sheet out!!! the settings actually made the blacks look purple, it was terrible.
post #2065 of 4975
Oh yes, I see them now:
http://www.avsforum.com/t/1470900/official-samsung-unxxf7100-owners-thread/2010#post_23633889
post #2066 of 4975
I'm currently on firmware v1104 and just found out that I can update to v1105. Is it safe to do so? Is there a website that will tell me what v1105 changes/fixes?
Edit: Just saw a post above me... is v1110 out now already? Guess I should hook my TV up to the net more often.
Edited by CurryStorm - 8/16/13 at 7:59pm
post #2067 of 4975
What the heck guys? I currently have a 46" polaroid I bought from Walmart that has none of the issues described in the 2000+ posts. Before I read all of these posts I was certain I would buy the 65" F7100 after next payday. What is the point in even buying a 240hz tv if everyone turns off the motion processing to avoid terrible side effects? I'm just a little skeptical at this point... If I pay $2000+ for a tv it better have "0" imperfections... Clouding, banding, flashlighting...really wtf? I have seen the tv at best buy and hhgregg, and it looks awesome on display with the samsung feed. What's with the problems? I mean damn if I wanted all these issues I'd buy a Vizio....
post #2068 of 4975
The problem with the "Samsung feed" or whatever junk they decide to play on display Tvs is it's basically a slide show of still pictures, and/or barely moving pictures. This is done strategically so you don't see the motion issues like banding, DSE, juddering, etc. The displays are also in a very well lit store which makes it almost impossible to detect clouding and flashlighting.
Well then there's the fact that you can buy 10 different units of the same EXACT model and get 10 different results. No.1 has bad flashlighting , No.2 has terrible banding and flashlighting No.3 has a dead pixel and dark patches in all 4 corners. No.4 has really bad flashlighting. Etc.etc.etc.
TV's are all **** nowadays. I seriously regret selling my 5 year old 40" Samsung 6series that had zero problems except for being to small for my living room. I've had 5 brand new TV's in my house in the past month and they all had serious defects. I wish I didn't sell that 40" already. If I could do it over I would wait for this generation of TVs to pass. LED backlit / thin cabinet TV's are complete trash. Plasma has its own issues but I might end up buying a place holder plasma to get me through this generation of crap !
post #2069 of 4975
I had an odd problem earlier today. Started a game on the PS3 and after the normal video mode switch, screen stays black, can't get the menu or anything. Holding the power button and the red light flickers but no response. Eventually I hear the small pop and it turns off. Then I turn it back on and the screen brightness acts very strange, going nearly-invisible dim after ~60 seconds. Bringing up the menu revives the backlight until it dims again. I went and fiddled all the ECO options off/on to ensure they were off, to no effect. Eventually I did a factory reset and all is well again.
Kinda depressing to see that kind of hokey behavior. As if there weren't enough problems...
post #2070 of 4975
While I agree with your sentiment, I should point out that there are definitely much worse issues than what we talk about here. I had a Sony W802A which was an absolutely putrid mess of shadows, clouding and flashlighting (I was so happy to get that out of my sight). I was also just watching a movie tonight on a friend's 2012 Panasonic LED, and it has really bad clouding, flashlighting and DSE.
(Panasonic's motion processing is definitely better than the F7100 though. "Weak" does a great job at reducing judder & edge flicker to acceptable levels, and I could not detect a single artifacts in about 2 hours feeding the Panasonic various anime clips I've seen have major problems on the Samsung.)
If I were you, I'd hold on to your current set for as long as possible unless it has serious defects.
