AVS › AVS Forum › Display Devices › LCD Flat Panel Displays › Official Samsung UNXXF7100 Owners Thread
Official Samsung UNXXF7100 Owners Thread - Page 95
post #2821 of 5010
No new 1115 showing up here on the eastern standard as of 12:30pm. Anybody else see this update yet?
post #2822 of 5010
I can see it here:
http://www.samsung.com/us/support/owners/product/UN60F6300AFXZA
Description as follows:
This firmware is for TV Model(s): LED F5500/F6300/F6350/F6400/F6800/F7050/F7100/F7150, PDP F5500
The version is 1115.1
This firmware update will improve the following:
- Solves Network Connection Issue with Wireless Router.
- Improves Picture Quality.
- Solves the issue Screen Mirroring does not work.
- Solves the issue Digital Clean View does not work correctly.
post #2823 of 5010
Firmware 1115- I see its on the website, but its not in the HDTV's direct live steam .
post #2824 of 5010
This is kind of weird that the downloadable avalibility is ahead of the Live Update function. Well I'm downloading it now. It's a very large file...When its done, I'l install it & report back later... Sure hope this latest version takes care of the stability issues in the Smart Hub without messing up the picture quality!eek.gif
post #2825 of 5010
+1, Me too.....
post #2826 of 5010
+1, Me too.....
Well the re-programming is all done after the Firmware Update and so far.. all seems very good. The picture quality is still looking Great! It is to early to tell about the stability of the Smart Hub. During the firmware update, all went OK and I didn't see anything that got messed up from installing the update but to be safe, I did the Factory Reset anyways. More comments later on after some real use with the Latest Firmware 1115.1.
post #2827 of 5010
I am having good experience with the latest firmware as well. I believe the picture quality has improved. Rendering of cable sources looks better to me. This was one of my grips previously and they are almost there on face render and colour. I am very happy with this set.
I have used calibration settings found here, and it looks quite accurate to me. Wondering if it would be a waste of money to get a professional calibration?
Comments?
post #2828 of 5010
Where are you guys seeing this new firmware update? I'm on version 1113, and it says there are no new updates at this time..
post #2829 of 5010
The download link is six posts above yours.
post #2830 of 5010
Despite my best instincts...I will wait on the reset.
Settings for DirecTV Movie, Natural, Standard and Dynamic plus Movie 3D, Standard 3D and Dynamic 3D takes time.
Not to mention Blu-ray Movie, Natural, Standard and Dynamic plus Movie 3D, Standard 3D and Dynamic 3D.
And then Xbox360 Movie, Natural, Standard and Dynamic plus Movie 3D, Standard 3D and Dynamic 3D & Standard / Game Mode.
post #2831 of 5010
Its only available from the Samsung Support website at this time:
http://www.samsung.com/us/support/owners/product/UN55F7100AFXZA
post #2832 of 5010
Originally Posted by pg22 View Post
I don't see an option anywhere to update my 7100 via USB - only an online option. I checked this guide: http://downloadcenter.samsung.com/content/FM/201305/20130511142111718/2013_TV_Firmware_Upgrade_Instruction_T-MST12AKUC.pdf
but it wasn't helpful. Am I missing something?
Page 2 and 3 explains the process I used.
post #2833 of 5010
I ended up figuring it out and deleting my post smile.gif but basically I just used a diff USB stick and it showed up! Thanks.
post #2834 of 5010
Do I need to download the firmware file on my USB stick and plug it into the tv afterwards to get the update? Help fellaz I'm lost Lol
post #2835 of 5010
Download the file to your PC's hard drive. Then unzip the file. Take the unzipped folder and copy it to a usb flash drive. Plug the flash drive into usb port on TV. After the device is displayed and initialized, Go to the support Menu and then select Software Update. Select the usb device with the downloaded 1115 version... That's about it. Once this process starts the actual firmware update, DO NOT touch ANYTHING!!! The TV powers OFF & then back ON after the 100% completed message is displayed. When all that happen's your'e good to go..... If anything is not working correctly with the latest firmware, Do a Factory Reset and have fun reprogramming almost EVERYTHING from scratch. I hope your'e now "Found".biggrin.gif
post #2836 of 5010
Thanks im found lol
post #2837 of 5010
post #2838 of 5010
Thanks I'm found lol
post #2839 of 5010
+1, Great Advice....this is my plan.
post #2840 of 5010
Hey folks, can anyone enlighten me on the difference between Film Mode: auto 1 and auto 2? Which one is best for hd cable tv? I have read multiple conflicting sources on the issue. I have my time warner stb set to "native" so some of the channels are input in 480i/1080i. The set defaults to auto 2. Thanks in advance.
post #2841 of 5010
Hi,
I just hooked up a sony str-dn840 to this tv last night.  The surround is 5.1 and for movies it sounds great.  But if I just want to put the news on it's all overkill.  I'm new to all this tech, but really I would be happy with just the tv speakers for that type of television.  Not sure even how to switch it back easily.
Also,  I have the ARC properly plugged in but on a test, a netflix 5.1 program gave only 2 channels to the receiver.
Also,  is there a way to use the samsung remote to switch sources still, now that everything is jacked into the back of the receiver?
Thanks for any advice!
post #2842 of 5010
I use Auto 1 for everything...it gives more detail for 1080i sources.
Auto 2 is best for channels with tickers- News and Sports.
I also leave Auto Motion Plus (A.M.P.) : Off most of the time.
A.M.P. used with Film Mode can cause slowdown and stuttering.
post #2843 of 5010
Originally Posted by bkandor View Post
Hi,
Press More on the remote there is a Icon that changes from Ext. Speaker to TV Speaker.
Use this to switch sound.
post #2844 of 5010
This just may be a version that doesn't require the Factory Reset. I did my reset anyways to play it safe. Before the reset, I did check for the things that seem to get messed up after updating but this time, all looked normal. Anyways, it's been a little less than 1 day with version 1115 installed and so far, NO stability issues have occured. I have tried NetFlix and many other Smart Hub applications without any issues I have noticed. Hopefully this Firmware Version may be the one to hang on to.wink.gif
post #2845 of 5010
What do u guys have your gamma set to?
post #2846 of 5010
Yeah, I hope so too...Fw. ver. 1115 looks stunning.
post #2847 of 5010
Gamma: 0 for 2D and -3 for 3D.
post #2848 of 5010
Just upgraded from 1110 to 1115. Netflix is stuttering a bit still with ethernet connected, not wireless. I'll try wireless when the kids nap.
post #2849 of 5010
I Can't do a live update yet? Don't know why?
post #2850 of 5010
Never mind seen that it can be done by USB, do we know if all updates will have to be done this way?
