AVS › AVS Forum › Audio › DIY Speakers and Subs › TD15M - SEOS12 - BMS4550 / theater progress / Dual TD6M - SEOS12 - BMS4550 build. :D
TD15M - SEOS12 - BMS4550 / theater progress / Dual TD6M - SEOS12 - BMS4550 build. :D - Page 11
post #301 of 314
Originally Posted by pgwalsh View Post
BA -
If the Statements don't impress, then we'll have to put you out to pasture.
I initially looked very closely at the statements before going with the AE's. I'm going to spend quite a bit of time over the next couple months going over additional room treatments before making any final judgements. They really do a lot of things well, if I could figure out the random harshness I would be perfectly content. Mat has offered additional help, I just need to find the time to do some more investigating. They are obviously not bad enough that I have quit listening to them. smile.gif
post #302 of 314
Is the harshness in the same place if you play the same piece over or just random? If you can reproduce it in the same place, it may be the content and it might just be revealed more now than before.
post #303 of 314
The harshness is definitely at a certain frequency. It manifests itself mostly in vocals, which leads me to believe it's either a xover issue or room problem. I never had this problem with my Axioms though, so it's a little surprising it could be the room, especially due to the fact that the wg's have a lot better directionality.
post #304 of 314
Can you reproduce it with a specific track or content? As in the same area etc. Just curious because this allow other's to test the same and possible lead to a fix. I've heard harshness in audio in some HD audio tracks, but I have attributed it to the actual recording, but your issue may be quite different and if it's not noticeable on other systems we could possible narrow down the issue.
post #305 of 314
Use a good pair of headphones. Do you hear the same harshness in those tracks? More than likely, it is NOT the room. Most logical is that something is poorly adjusted in your design, or you've found a few recordings that have issues of their own and the new speakers are showing you these problems more clearly than you are used to.
Greg
post #306 of 314
Greg
I'm familiar with good speakers revealing flaws in poor recordings. This isn't it. It manifests itself during both movies and music.
post #307 of 314
Happens with Audyssey on and off?
post #308 of 314
I think so lol. I've gone through so many different scenarios, I've forgotten.
post #309 of 314
I've had Audyssey make the mids honky and harsh before. I don't like to use it anymore.
post #310 of 314
Travis, have you done anything else with these yet??
post #311 of 314
Bass Addict, you had mentioned In another thread about re-doing your LCR x-overs to Mtg90's newer design, has this happened yet?
post #312 of 314
Funny you should mention that. They are sitting on the speaker right now ready to get reinstalled.
I'll have some updated listening impressions in the next few days. I'm just finishing up my other sub box, so after this is done I'll get everything back together and tweaked.
post #313 of 314
When you get a chance, I'd love to hear your impression.
I bought the parts for Matt's Rev. 1 (TD15M-4 +DNA360), and when I finally got around to building them out he released Rev.2, so I purchased the needed parts & built those out instead.
I love them, a lot more depth than my TD12M-8 + DNA360 build, but I love those too.
I have no means of measuring yet (other toys I want first), until then I go by others impressions, and I like your honesty In such.
post #314 of 314
Well I got them put back together yesterday and sat down for a brief listening session with some SACD/DVDA. I will say that the system definitely needs to be re calibrated prior to making any conclusions. With the new crossovers, the levels got pulled down a bit. My surrounds are overpowering the mains by a fair margin. I only listened to a couple tracks but the initial impressions are encouraging. Once I recalibrate everything I will sit down and give some more in depth detail.
