AVS › AVS Forum › Display Devices › LCD Flat Panel Displays › Need advice for unique situation, Best LED Option at BestBuy, Better to buy 2012 top of the line or 2013 mid-range?
Need advice for unique situation, Best LED Option at BestBuy, Better to buy 2012 top of the line...
post #1 of 2
OK, so I'll skip the long drawn out part that tells how I got here, but the short version is the Pana Plasma had issues and I rue the day I made the decision to bring it home. RUE! So here I am with a bestbuy credit, and I am absolutely zero percent inclined to get another plasma. So, LED for me, but I'm not sure what's been happening with the 2013 models, if it's all fluffy feel-good features, or something substantial feature set has appeared that I might want.
Budget 1300-1800
Store must be BestBuy
Must be 55" or 60", probably prefer 55"
Only need 1 HDMI
Don't care about 3D, Inputs, 24p, etc
ABSOLUTELY looking for best 2D picture, great blacks, great uniformity (within my budget of course)
Low lag very important
My options just quickly looking on the bestbuy site:
Pana
TC-L58E60
TC-L55WT50 (current favorite, but I know zero about LED tvs)
LG
55GA640
55LA6900
55LA7400
55GA7900
55LM8600
Samsung:
UN55F6400AFXZA
UN-55ES7150
UN55ES7003FXZA
UN55ES6580F
UN55F7100AFXZA
Any advice on what is the most cost effective route? I DO NOT want to be buying another TV for a few years!
If anyone would be so kind as to give me a top3 options that would be REALLY helpful!!!
Edited by iso9001 - 5/2/13 at 3:55pm
post #2 of 2
See if any stores have the Sony HX850. It gets great reviews and now that the 2013 models are coming out you should be able to get them at rock bottom prices, assuming you can find one.
