AVS › AVS Forum › Display Devices › Digital Projectors - Under $3,000 USD MSRP › Panasonic PT-AE7000U image not squared
post #1 of 2
hey guys I have a 92" 16:9 screen pull down. The PJ is mounted on the ceiling,6" to 9" adjustable peerless mount. The PJ is not centered with the screen,it is about 6" off center to the right due to a ceiling fan. I am getting the left side is taller than the right side. The bottom angles up towards the right. It is about 1" difference. I have tried everything I think. not sure if there is something internal in the PJ or what. What to do?????????????
post #2 of 2
Normally that can happen if the projector isn't level, front to back, and side to side. Set it to level, and then project the image so it's square onto the wall, then use the lens shift to bring it over/down onto the screen.
