AVS › AVS Forum › Display Devices › LCD Flat Panel Displays › LG 55LW5300 Image Problems.
post #1 of 6
i just recently bought a lg 55lw5300 from craigslist, stupid me didnt check all of the settings before buying and just looked at it they way he had it set up already.
so i get the tv home and the image is too bright for my taste, like a normal person would do i go into picture settings and move it to the other preset's just to see how they look, thats when i noticed a big problem. im not sure how i should describe this or what its called but from my gaming days it looks like crazy bad gamma or a inverted image. so did i just buy a broken tv or is there some magical way to fix this?
i have updated the firmware to 5.00.01 that did nothing though. here are some pictures to show you what im talking about
is the video processing unit bad? i dont think its the screen itself though i could be wrong
Update:
i have tried switching out the t-con board with a new one, had no effect on the problem.
Gear mentioned in this thread:
post #2 of 6
no one has any ideas? is it that rare of a problem
post #3 of 6
anyone? about to just pop it back on craigslist and let someone else deal with it
post #4 of 6
I can't really say for sure but I think that it might be a problem with the mainboard. I have seen similar things before with that being the problem but I can't say for 100% that that is the problem you are having nor do I know if you want to spend the money testing that out.
post #5 of 6
How would I test it? Just swap in a new one. I don't have a problem doing that, already tried the t-con. Just have to find someone that carries the main board, internet search turns up nothing for this particular board.
post #6 of 6
Swapping it is what I would do to see if it works. They are out of stock right now but shopjimmy.com sells parts for your TV. You can either sign up to be notified when they will have it in stock again or do a search on the internet with the part number (you can probably find it on eBay but there is always the risk that you could get a bad board so be sure to make sure whoever you buy from allows returns). You can also contact LG, they might have a place where you can buy parts (I know that Samsung does).
