AVS › AVS Forum › Gaming & Content Streaming › Home Theater Gaming › Xbox Area › CAN I CONNECT US XBOX360 & SPEAKERS TO UK RECEIVER?
post #1 of 2
Hi,
Just wanting to know from anyone if I can connect a US Xbox360 110v console to a UK 220v Denon receiver via HDMI without messing it up? I am living in the UK for now and looking to return to Australia and just want to confirm whether or not I should buy the receiver in the UK (much cheaper) or from the US and keep the power supply consistent via a transformer?
Also, on a similar note, can anyone advise whether or not I can connect speakers from a US 5.1 Sony home theatre system to the same 220v UK receiver?
As I need to make a decision quickly, any timely assistance you can provide will be greatly appreciated.
Cheers.
post #2 of 2
This should be fine. You just would need to make sure the XBox power is plugged correctly into the power. HDMI specs do not change based on the country, electrical power does.
The same should apply to the speakers.
  Back to Forum: Xbox Area
