AVS › AVS Forum › Display Devices › CRT Projectors › Barco remote died...
post #1 of 5
I have a Barco 808s and the remote just died...
I am using my spare (also a real Barco remote from my spare 808s) but it doesn't seem as "strong" as the original one was.
i have to hold the stby button hard for a second to turn on and off the projector.
Anyone know if these units are serviceable?
thanks
Scott
post #2 of 5
  • Turn off the projector with wired remote.
  • Press the recessed button (below "adj" button) with a pencil.
  • Then press the button of the projector address (usually 0 "zero").
  • Try turn on with remote.
post #3 of 5
Decibel62 i am forever in your debt.
the reset worked like a charm.
funny though, i reset it once 12 years ago when i changed batteries, and since never needed it.
its all good now, thanks
Scott
post #4 of 5
wink.gif good
post #5 of 5
will this work with the newer control as well (mines from a cine 7) backlit one just went dead and wont even light up???
  Back to Forum: CRT Projectors
