This is probably not too interesting to some, but I've re-designed the Projector Calculator, and after a lot of hard work, I thought I'd post my progress. The "it's ALIVE" thread will be later. As I had noted in my other thread about my new project (Sim Theater), I am first finalizing the pre-cursor version of the Web Calculator first.
GUI has been substantially improved and cleaned up.
3D Lumens Mode now gets a dedicated box
Convergence Grading System has been added. 6 large simulated pixels on the screen allows you to set how your projector's convergence looks, then it will give you a grade.
Clearance Seating Calculator to allow you to see a ruler of every X feet back from the screen, how high the projector's beam clears your objects like seating in the room.
Filters have been added so you can show projectors "Only with 3D" or "Only above 1000+ Lumens Best Mode", or ONLY DLP only LCD, etc..
Calculator will be renamed to WebProjectorCalculator.com and all products will fall under the name "SimTheater.com".
---Bunches of other changes I will list upon release---
Here is a screenshots of the progress:
Here is a picture of the old version (yuck compared to the new one ABOVE IMHO):
