AVS › AVS Forum › Display Devices › Plasma Flat Panel Displays › How To Disable Internal Speakers In The VT60?...
post #1 of 2
...I got the Z-VOX555 today and hooked it up using the optical audio out jack under the HDMI inputs of the TV. Problem is I can't seem to find a setting that allows me to "tell" the TV that I'm using an external sound system and to disable the built-in speakers. I'm thinking that there has to be a way and that I'm missing something. Can anyone give me a step-by-step procedure to follow to mute the onboard speakers. As it is the sound output is about a half second out of sync between the built-in speakers and the external soundbar.
Any help appreciated.
post #2 of 2
I think i saw it discussed in the 2013 Settings Issues thread, and in this thread:
http://www.avsforum.com/t/1470804/help-disabling-speakers-on-st60
