AVS › AVS Forum › Gaming & Content Streaming › Home Theater Gaming › PlayStation Area › PS4 Dual HDMI Output is used for what?
post #1 of 19
Multiple displays?
Can one HDMI transmit video directly to a display while the other transmits audio to an AVR?
Both?
post #2 of 19
Normally this is used for 3d for receivers that don't support3d so one for 3d video direct to tv and one for audio to receiver
Sent from my iPad using Tapatalk HD
post #3 of 19
While I'd assume you are correct, as this was my hunch too, have you any sources?
Even though I don't have a 3DTV, I'd still be tempted to run HDMI straight to the TV for video and to my Denon AVR for audio.
post #4 of 19
Same theing the PS3 dual HDMI out does -- oh right -- feature disappeared before retail --
post #5 of 19
Maybe for receivers that don't support 4K?
post #6 of 19
You may be onto something with that idea.
post #7 of 19
Why would 4k and HD require separate HDMI outs? The PS4 decides on the output and the connector just transmits whatever is given to it. The new HDMI spec should be able to transmit 4k on down to 480i.
post #8 of 19
I read awhile back that devices with 2 HDMI outputs are for audiophile/videophiles that feel having one cable to TV and one to the receiver improves a/v quality.
post #9 of 19
It would be videophiles that have receivers that cannot pass through video untouched or at 4k. I think it will get left off because if you upgrade to a 4k tv, you can probably afford a new receiver. Most receivers will be able to pass 4k before most people have 4k receivers. It just does not make much sense for a device that will be sold at a loss.
post #10 of 19
If you have a 4K tv (the only reason the PS4 would be outputting a signal in 4K) and you don't have a receiver with 4K pass-through, you could run the 4K video direct to the TV, and just the audio over the other HDMI to the receiver. Just like many 3D blu-ray players (oppo BDP-103 for example) do today. This removes one more barrier to buying a 4K TV, as if you just bought a really high end receiver in 2011, you wouldn't have to upgrade it. Sony frequently takes a long-term view of these things and is probably hoping that the ability of the PS4 to output both really high quality 3D, and some type of 4K content will entice people to buy some of their TV's, either 3D or 4K. The extra port would allow non-3D receivers to be bypassed as well.
post #11 of 19
Similar to what Mountain said maybe Sony is trying to get into the high end video world.
Oppo buyers tend to go with their players for the fact that it has 2 outputs, the best picture available to you is when it is directly from the player to the display, taking your AVR out of the path.
If Sony is hoping to go toe to toe with the big guys in the Blu-ray world, this is a good first step.
I know the PS3 was the yardstick blu-ray players were measured by for a good few years, maybe they want that title back.
post #12 of 19
So is the PS4 going to have dual HDMI?
post #13 of 19
I've seen no indication that it will....everything I've seen so far indicates a single HDMI out port.
post #14 of 19
I am betting it becomes just one HDMI port like the PS3 prototype, but it would be cool if they allowed multiplayer with 2 screens on one playstation
post #15 of 19
That is what I was thinking. It would be so freaking cool if they could figure a way to allow you to hook up two displays for FPS games like COD. That way when you play locally (if you have the equipment) you could have you and your buddy on separate screens vs. getting the tiny (when not on a PJ) split screen garbage.
post #16 of 19
On a 3D capable display, you could get two separate full screen images with the right glasses. They've dipped their toes in this kind of functionality with the PS3, I expect it'll be pretty standard with the PS4.
post #17 of 19
It does indeed look like Sony wants to enter the fray of high-end. What's interesting is the fact that this is completely possible. The Sony S790 is rated by at least one publication (Home Theater Magazine) to have video quality that matches Oppos BDP-103's capabilities. If Sony can replicate this level of performance in the PS4, and include dual HDMI outputs currently valued by videophiles and audiophiles (I run dual HDMI from my Oppo 105 for the signal path reason mentioned above), then the PS4 could be a real contender. Lab measurements consistently show receivers and pre\pros as having an effect on the video signal even with processing disengaged.
post #18 of 19
post #19 of 19
From the spec sheet it looks like it only has 1 HDMI out.
http://www.computerandvideogames.com/412685/playstation-4-full-final-specs-revealed/
AV output: HDMI out port, DIGITAL OUT (OPTICAL) port
  Back to Forum: PlayStation Area
