AVS › AVS Forum › Display Devices › Display Calibration › Color saturation and luminance
post #1 of 4
My Toshiba 46sv670u seems to do both when the color bar is moved postively. I did a by eye calibration to grayscale using my dve disc and expert mode in the TV menu. When increasing color I noticed some artifacts mainly while watching programming on Directv HDDVR.
So I was wondering what was causing the artifacts to appear.
For reference here are settings:
Backlight 60
Contrast. 75
Brightness. 15
Color. 0 center
Sharpness. 0 center
Static Gamma. 0 center
post #2 of 4
Cable and satellite are LOADED with artifacts all the time. They cannot be used for ANY sort of evaluation. The compression applied to video (and audio) by cable and satellite services does not even preserve 1920x1080 resolution and, by all rights, the "HD" you get from cable and satellite should not be allowed to be called "HD". It certainly looks better than SD, but Blu-ray discs are the only true HD source we have right now. And Blu-ray is far from perfect... it really needs more bits (10 would help, 12 would be ideal) and less color decimation and a wider color gamut. In fact , during scenes with a lot of motion, I've estimated on-screen resolution from cable and satellite in the 200x100 range because the block artifacts are so huge. (just pause a frame on an explosion or some other full-screen motion using a cable or satellite DVR to see how horrible the resolution is).
That said, Toshiba TVs I've reviewed in the past have HORRIBLE problems generating posterization and block artifacts after adjusting the CMS controls more than 1/3 of their adjustment range (on TVs with adjustment ranges of +/- 10, I didn't see problems when using adjustments of +/-3 or less, with TVs having an adjustment range of +/-30, I was able to use adjustments up to +/-10 before seeing the artifacts. I didn't really try moving other controls much to see if that also produced artifacts, but it is possible they could. Toshiba designs seem to have limited capacity to make adjustments without negatively impacting image quality... at least for some controls.
post #3 of 4
In the CMS, the only color with adjustments is blue.
-13 hue. +3. saturation. 0. brightness
Color temperature 1
Red-offset. -11
Green-offset. -6
Blue-offset. -13
Red-Gain. -4
Green-Gain. +4
Blue-Gain. +6
Dynamic Contrast 0
I have no red, green, or blue push to speak of. I'm actually amazed at the picture quality I achieved and how close I am to gray scale.
Almost forgot Tint 14 towards green. Does contrast affect luminance ?
post #4 of 4
Contrast IS luminance.
Read my previous post again... I outlined how far you can adjust the CMS controls and your list makes it appear as though there are adjustments outside the range I said would be OK. So it's not surprising you are seeing artifacts.
