AVS › AVS Forum › Blu-ray & HD DVD › Blu-ray Players › Playing music files from external hard drive on OPPO 93
post #1 of 2
I have been trying to play music files using the USB input. The only problem I am having is that every now and then, the music pauses( less than a half second) and it almost sounds like a skip on a cd. I know the source files are good. Is there a limit to size of hard drive that can be used? The drive I am using is 200GB IDE drive in an external case. Would this work better with a faster SATA drive? The files I am playing are in folders with the album name and the songs are in the FLAC format. Has anyone had the same issue and if so were you able to find a solution? t. Any other other ideas? Thanks.
post #2 of 2
Welcome to AVSForum.
Please post this sort of question in the BDP-93 owners thread: http://www.avsforum.com/t/1291855/official-oppo-bdp-93-owners-thread
Maximum HD size on the -93 is 2TB. USB is fast enough.
Have you tried different devices? As a test, I would try a thumb drive, which are usually trouble free (although they do fail from time to time).
-Bill
