AVS › AVS Forum › Audio › Soundbars › YSP 5100 problems with Apple TV and Viera Link
post #1 of 3
Hi there,
I bought the YSP5100 and my Panasonic Blueray + TV worked fine using Viera Link...now, it doesn't work anymore. I have to use a separate remote for the Blueray.
Also, my Apple TV worked at first but now I can't get any picture+sound through the YSP. I tried to switch HDMI ports and cables, resetting, didn't work! Would appreciate any help!
post #2 of 3
Hi,
Kick the apple resolution down to 1080i or 720P. hook the apple tv straight to the tv to do this and then after that, hook Apple tv back to the soundbar.
post #3 of 3
Hi force10,
Will try and let you know. Thanks!
  Back to Forum: Soundbars
