AVS › AVS Forum › Audio › Home Theater In A Box › Help me choose a budget system for small room
post #1 of 4
The reason I'm looking at this type of system is space, I have a room 24 feet by 20 feet.
I don't want standing or tower speakers as I really don't have the space for those, I need small portable speakers.
I also don't need a lot of power for a room that size, nor do I want a super powerful system as I live in an apartment, I'm more interested in immersive clear sound at low volume.
locally I can buy:
Energy Take 5.1 - $200
Acoustic Research HC6 - $180
On Amazon.com:
Polk Audio RM705 5.1
http://www.amazon.com/Polk-Audio-RM705-Theater-System/dp/B000WGJX5A/ref=dp_ob_title_ce
$190
Jamo S 426 HCS 3 WENGE
http://www.amazon.com/Jamo-426-HCS-WENGE-5-Piece/dp/B003GGXGU6/ref=sr_1_14?s=aht&ie=UTF8&qid=1367772113&sr=1-14&keywords=klipsch
$176
I'm so torn between all these systems, which would be best?
Edited by witchcraftz - 5/5/13 at 3:47pm
post #2 of 4
Well, the Jamo has tower speakers, so wouldn't that be out? Although, that's the one I'd go with, no replacement for displacement, as they say. I had the Energy Take Classics, they were pretty good. I imagine it all comes down to preference (sorry!), which one sounds best to you, and all that.
post #3 of 4
Keep in mind with the Jamo, you would still probably want to add a sub.
post #4 of 4
I ended up getting the Energy Take 5.1, I must say they are fantastic. smile.gif
  Back to Forum: Home Theater In A Box
