AVS › AVS Forum › Blu-ray & HD DVD › Blu-ray Players › Panasonic Player does not turn on
post #1 of 3
I recently turned off my player while it was updating. It seemed to be hanging so I figured if I turned it off then on again it would be fine. Now, It doesn't respond to anything. Is there a way to do a factory reset of the machine or am I out of luck?
post #2 of 3
Welcome to AVS. Please post in the thread for your player. Reset procedures are in the owner's manual in the troubleshooting section.
S~
post #3 of 3
Unfortunately, that is a great way to brick your player. Check your manual to see how to do a factory reset. Also try contacting Panasonic customer service.
