AVS › AVS Forum › Audio › Home Theater In A Box › Wireless options for surround sound?
post #1 of 3
Are there any good wireless solutions designed specifially for surround sound - preferably a system that gives me the freedom to use whichever speakers I choose?
I'm guessing if it exists, it would involve a small receiver for each speaker?
post #2 of 3
The only wireless part of wireless systems is the connection between the sides and the receiver (front sound stage). The side speakers need a powered outlet to plug the receiver in and then both of the speakers need to connect to that receiver with wires. Some systems may have a separate receiver for each speaker but they still need to be powered somehow.
post #3 of 3
KEF I think had a system that allowed all the speakers to be wireless in terms of the audio signal. But as Otto said, it still needed power cords for all the receivers.
  Back to Forum: Home Theater In A Box
