AVS › AVS Forum › A/V Control & Automation › Home Automation › iPad/Tablet Wall Mounting Thread
post #1 of 15
I'd like to compile information for use so that I can hopefully find a better product than what I have. My ultimate goal would be to flush mount my iPad in the wall with a power source and be able to pop the iPad out if wanted, though the solutions that do that are a few hundred dollars. So what I'm going to do is start a list with the item name, website, USD purchase price, and a picture. If you have any other info to contribute let me know.
Threads/Links
iPad as wall mount touchscreen
Cocoon Tech Website
DIY Link
iPad Mounts
  1. Channel Vision On-Wall Docking Station - $165
  2. LOXONE iPad Mount - $40 (ships from Europe)
  3. Vidabox - Various (no iPad 1) - $100
  4. ProClip Wall Mount Holder (There are other mounts from ProClip too - $50
  5. Wallee / Studio Proper Wall Mount System - $50 (includes cost of the wall mount disc)
  6. iPort - Control Mount - $595 (Couldn't find a good link on their website so listing Best Buy retail)
  7. Crestron in-wall iPad Dock - Not really sure on price or where to get, this one lists it at $370
  8. Savant In-Wall Dock - $$$???
  9. iRoom iDock Alu Portrait - No idea on price
  10. Trufig - Again not sure on price
  11. Koala iPad Mount - $20
  12. iPort LaunchPort System - ($350)
Universal Tablet Mounts
ProClips Makes some
Wallee Makes some
Koala Above is universal
"Kiosk" Mode
So I wanted to also make the device somewhat user friendly and in a way "secure" so that if I have people over the "Remote" application will always be there and so someone might not accidentally screw something up. To do this you have to jailbreak your iPad then install the following:
  1. NoLockScreen - Disables the lockscreen entirely so that the device can be brought back from sleep with just the home button and you don't need to swipe to unlock the screen
  2. AppLocker - Allows you to enable a password for any application. Essentially for this iPad, I enabled AppLocker on every app but Remote, Safari, & Weather
  3. IncarcerApp - Allows you to set a hot key so that you can "lock" an app, further, once an app is locked, you can disable the sleep button and the home screen button. This way someone can't power cycle the device or get out of the app. To get out of the app, you just double-tap a special area of the screen.
Edited by akevit - 5/13/13 at 12:07pm
post #2 of 15
iPort looks the best and is available for $300. But I would be tempted to DIY with one of the clip mounts and a custom faceplate out of laser cut material. Not sure what I would do for the backer box though.
post #3 of 15
I was discussing with a friend some possibilities for this, it seems like it would be completely feasible to get a bracket in the wall then fix a case to the bracket for the iPad. I haven't come across any that have been done and haven't done much research on cases that are out there. I'm just starting with the Koala one since it's cheap and simple to install. I couldn't decide on anything else and just wanted to get it up there with something. I'm pretty sure I can cover the blue backing with another color.
post #4 of 15
The two best that we have used are the Launchport and the Crestron in-wall dock (the picture in the original post is actually from one of our installations). While they are expensive, you get what you pay for.
post #5 of 15
ive got the loxone mount
pros:
- simple to install
- easy on and off
- clean look / thinnest bezel option / unobtrusive
- cheap
cons:
- if you knocked it hard the ipad would fall out and onto the floor
post #6 of 15
The iPort products are awesome, but if I were going for near flush with removable, then I would go with this:
http://www.launchport.com/
The Launchport is actually an iPort product, but I absolutely love the inductive charging and the complete on/off ease of use. You can put up a wall charging unit and put your iPad into a sleeve and then just slap it up on your wall. Rotate it portrait or landscape as you choose. The magnet is the right amount of strong without making it impossible to remove the iPad from the wall station.
Yes, it does protrude, but it is well under an inch and is more like a photo on the wall. I'm sure that there are ways to customize this to get it more 'flush', but it may make it difficult to take off the wall.
Just my $.02 on things.
post #7 of 15
Hmm Launchport looks nice but yeah a little spendy, also there is no case for the iPad 1G it looks like.
Here's the Koala Mount:
post #8 of 15
Yeah, no iPad1 version for LaunchPort, and I wouldn't hold my breath for one. But, the inductive charging is really nice and the fact that it is upgradable as your iPad changes to new products is really cool. Potentially, they could make sleeves for it in the future which would work with a Samsung tablet or other products is also a really cool thing. I've hands-on tested one and it is by far my favorite as being a professional 'high-end' product. But, I don't own one. WHY? Yep! It's pricey! smile.gif
post #9 of 15
Yeah I just called them, no ipad 1. And so far, no Nexus 7 Android. I guess a used iPad2 for $300 and this kit which you can find both pieces for around $325 make for a $625 wallmounted touch screen.
I was going to try this for the living room, a place to charge the ipad, but as you walk in you can grab it, sit down and use it as the remote. Whether Control4 or iRUle this would be pretty good as a remote to control shades, lighting, and TV etc.
Even as a place for the kids to be able to charge their iPads.
post #10 of 15
Great thread. Time to research for my build. Thanks for the head start
post #11 of 15
post #12 of 15
Smart-Things sDock
From Europe.
http://www.smart-things.com/en/sdock-pro.html
post #13 of 15
pros:
- simple to install
- easy on and off
- cheap
cons:
I hate imagining the ipad falling. My #1 ipad rule (and only rule generally) is don't drop it.
post #14 of 15
If anyone is looking for a DIY solution for an Android tablet, see mine here with inductive charging and very minimal equipment on the wall:
http://www.controlmypad.com/projects.html
It also holds my iPad2 (see bottom of page in above link), but only as a holder (Apple hasn't caught on to joys of the inductive charging yet) since I added a strip of steel internally for the magnets to grab onto.
I may have been able to shave off the "ledge" as some have asked me, allowing only magnets to hold the tablet, but the "ledge" marks where the tablet goes and provided that extra bit of support so I never have to worry about it dropping.
post #15 of 15
Love it! Nice work and thanks for sharing.
  Back to Forum: Home Automation
