AVS › AVS Forum › Video Components › Home Theater Computers › Selectively Syncing Media Between 2 Computers
post #1 of 11
I've spent the day researching and looking around at a number of options to sync media between 2 locations, and figured I'd ask the gurus here for any suggestions.
I currently have a media server (FreeNAS with 6TB of space) that feeds the Boxee box that I have currently on my LAN. I'd like however to selectively sync some of the media on that server to another location that I will have just a raspberry pi running XBMC served up by a small linux box (pogoplug running arch) that will just have a 500GB drive connected to it. This location won't get used much, and is connected just over an internet connection that is mostly idle, so I wanted something low power but still serving up media locally.
For example, lets say I have:
Code:
[Folder: TV]
   [Sub Folder: Show 1]
   [Sub Folder: Show 2]
   [Sub Folder: Show 3]
   [Sub Folder: Show 4]
   [Sub Folder: Show 5]
Folder: Movies]
   [Sub Folder: Movies 1]
   [Sub Folder: Movies 2]
   [Sub Folder: Movies 3]
   [Sub Folder: Movies 4]
   [Sub Folder: Movies 5]
   [Sub Folder: Movies 6]
As I don't have as much storage at the second location and don't want to have to build out a whole NAS box just to sync everything, my idea would be to just select maybe Show 1, 2 and 5 from the TV folders, and Movie 3, 4 and 6 to have sync'd between the main site and the remote location.
I'd thought about OwnCloud, or Torrent Sync, but neither of those seem to allow you to select individual directories in a top level directory to sync. I could add the separate TV and Movie Folders, but on the remote side they'd all end up in one folder, which isn't optimal for scanning in XBMC or the like.
The second piece of the puzzle would be how to select these files to be sync'd to the remote end. I figure a remote desktop or port forward to the web gui of the sync program would work so that I could set the files to sync even away from the main site.
Anyway, any ideas or thoughts? Anyone else done something similar within a local site, or across multiple HTPCs?
post #2 of 11
Have you looked at SyncToy?
I have Task Scheduler running it on a regular basis. I sync SOME of 1 drive to another drive...
David
post #3 of 11
David
I was going to post this as well. Great software.
post #4 of 11
********** sync program is fast, free and unlimited
post #5 of 11
Bit torrent ^
post #6 of 11
I'd post the link but its blocked even though its a legal software that has nothing to do with the real bit torrent. It just uses the bit torrent protocol to sync multiple machines.
Anything in the folders set to sync will
post #7 of 11
If you're only syncing between two computers, any type of torrent is pointless. You're still limited by the upload speed of the sending computer or the download speed of the receiving.
A simple script running rsync across a ssh tunnel will have less overhead.
post #8 of 11
But that's not as easy for a newb as just installing a free program with unlimited sync- and actually the speeds are quite good.
post #9 of 11
Thanks for the input. I'm actually leaning towards the rsync path, and now I've somewhat decided to try to make it more complex by creating a web front end that will allow me to select folders graphically via a web browser, write those to a file and use that as my source for rsync.
I may end up biting off more than I can chew, but it'll be something fun to try.
post #10 of 11
What did you discover? Any luck or feedback ?
post #11 of 11
+1 for SyncToy.
