AVS › AVS Forum › Video Components › Cable, Digital Cable - Non-HDTV › omron xm2s-09 cable
omron xm2s-09 cable
post #1 of 6
confused.gif Can this cable be used to connect a PC to HDTV, It has 5 rca 's on one end and vga on the other..... just never ran across a cable like this and need advise asap,.. Thanks
post #2 of 6
Are you sure it's a DB-15 (VGA connector)? I see DB-9 listed: http://www.plccenter.com/en-US/Buy/OMRON/XM2S09
post #3 of 6
Vhy not use VGA or HDMI?
post #4 of 6
Yes, I am sure... and confused smile.gif ...... To answer blueiedgod, the tv does not have hdmi connection
post #5 of 6
Is it the old tube TV? Most of them have S-video. You just need a video card that has S-Video.
If you get VGA-to-Component cable to work, please post back. That would be valuable information for future visitors.
post #6 of 6
No it's a older (projection)HDTV, has the rca wires. I am going to test the weird connecter and try to put a pic up for viewing...... I think it could possibly be for med equipment to pc ?..... we will see
  Back to Forum: Cable, Digital Cable - Non-HDTV
