AVS › AVS Forum › Display Devices › LCD Flat Panel Displays › Recommend a TV - 70-80"
post #1 of 4
I have a 55" LG LED 3D tv, which I am happy with sitting 12 feet away in the apartment.
Will be moving to a house and the distance I measured will be 15-16 feet from the back wall. What size would be best. I guess bigger the better, but can I get away with 70" or do I need a 80". Can I hang this size tv on the wall?
Is sharp the only one who makes 80" tv. I don't need 3D, but if I get it for a good price, I will take it.
here is the layout of the room. yellow marks the potential for 5.1
post #2 of 4
THX calculations will reccomend 100+ inches. I am 14 feet away and I have a 55"...I wish it was bigger smile.gif but I refuse to sacrifice image quality for a larger screen. Projectors can always bump that image size up smile.gif
What's your budget for screen? Do you have home theater already?
post #3 of 4
This is the family room so no projector, there is not other dedicated HT room.
post #4 of 4
If you are happy with an lg 55" at 12 feet, you will be happy with a 70" at 15 feet. You actually have several options including the just released Sony 70" r550 and soon to be released vizio m series 70" or 80".
