AVS › AVS Forum › Audio › DIY Speakers and Subs › On/Off - Relay solution for Pro Amps ... anyone used Insteon?
post #1 of 10
I use iRule for my HT and this product claims up to 20 amps (most 12v triggers I see are 15 amps). For the price, seems like good deal and you can easily add it to your power on/off macros. Anyone tried one?
http://www.smarthome.com/2475SDB/In-LineLinc-Relay-INSTEON-Remote-Control-In-Line-On-Off-Switch-Dual-Band/p.aspx
post #2 of 10
I'd be interested to see if this would work well.
post #3 of 10
I'm within a couple weeks of starting a build, so maybe I will be the guinea pig .. I was hoping someone else had already done it or could advise why not to do it.
post #4 of 10
I've got my crown pro amp hooked up to a light switch that is there to control a plug socket. It's only an xls1000 so not too concerned, works great for us! Flip the switch for bass...
post #5 of 10
I have these INSTEON wall outlets in my bedroom running some lights tied to a single wall switch. I'm not sure if they'll handle an amplifier but they say rated for 15A. From what I can tell they may be solid state relays cause they are pretty expensive and no mechanical noise when switching.
Note which model you buy cause the ones I have only the TOP outlet is switched or programmable; the bottom one is a pass through.
Worth a shot.
on second thought i'd scratch the idea
(incandescent loads) only is what it's rated for
Edited by autox320 - 5/10/13 at 9:23am
post #6 of 10
Worth a shot.
I see, so if they're rated for incandescent loads then it's essentially a constant load rating vs a varying load? A high enough incandescent load could work couldn't it, like 20 amps for~15 amps of amplifier (varying) load?
post #7 of 10
Hi SuperEdge,
When they say "incandescent load" only, what they really mean is "non-reactive" or "resistive" loads only. An inductive load, like the power transformer inside your amp, would cause problems for that module.
They do make "appliance modules" which are designed for reactive loads, like motors. One of those would be appropriate for an amp.
I tried Insteon when it was first released, and it was unreliable. Seeing as they are still around years later, I would assume that they have addressed those original issues.
post #8 of 10
Originally Posted by MarkHotchkiss View Post
Hi SuperEdge,
I figured if they're 277v rated, they would be able to handle various phase angles? However, if an amp had a PFC of 0.98-1.0, that's close enough to being purely resistive?
post #9 of 10
I use one of these:
http://www.amazon.com/Belkin-Conserve-Socket-Energy-Saving/dp/B003P2UMQ2/ref=pd_sim_e_3
I have an Onkyo TX-SR703 (that's what I have plugged into the detection socket) and a Crown XLS 1000 and a Crown XLS 1500 that I'm switching.
post #10 of 10
Hi LooneyBomber,
Good point. The problem with reactive loads is that the SCRs or triacs shut off when the current reaches the zero-crossing, and not the voltage. So any PFC device should be ok.
